×Hello Community,
Quick question about a Automation Trigger via Schedule,
Not sure when we select the "On the" "A date" we should expect a date picker?
As i have a target to Run an automation in every 3 months (ignore the 1 month in the picture), but starting only on October 1st.
Try a CRON expression (like shown below):
Thanks for the tip Laurie,
i think this one made the trick
Great! If you wouldn't mind marking this as answered, I would appreciate it!
Even though you have an answer using a CRON expression, I recommend submitting a defect to Atlassian Support for what you have found. As the site admin on a paid, Jira license you can do that here: https://support.atlassian.com/contact/#/
I see the same thing and that value "A date" is not selectable...even though it seems to indicate picking a specific date is possible. I was unable to find this symptom in the public backlog for automation rules.
When you hear back from the support team, please post what you learn to benefit the community. Thanks!
