×Hi Folks
Having a lot of fun with Jira Automation. Just one flow I can't get my head around is at EPIC only level
When a new EPIC is created, I want the following actions to happen
- manually create Epic with Status TO DO
- Automatically, add "default" content to the epic description
- Then update the status to x
- Maybe even create a single default story.
Jamie
Hi @Jamie Scott
Would you like this to happen every time an Epic is created? You could try an automation like the picture below:
It's not perfect and will probably need adjustments, but that automation should do the basics of what you are asking.
Tim
And added the text I wanted to be populated in the new Epic with the Description Field.
