×I've created an automation that upon creation of a subtask, it should automatically copy the parent task's Component field to the subtask.
However, this doesn't seem to be happening for some reason. Whenever I create a subtask on a parent ticket with a Component filled in, it doesn't copy over the components.
The audit log says that the operation was successful, which clearly it didn't do what it was supposed to do.
I've tried the following:
I'm at a loss as to why this isn't working. It's clearly identifying the ticket as a subtask upon creation, and when using a specified component works correctly. I do not understand why the Copy from Parent issue doesn't work.
Ok I think I figured out what was going on. I was attempting to build two automations, one that copies components on create and another that copies components onto subtasks when the component on the parent task was edited. Both automations were turned on. I think the second automation was nuking the component on the parent task whenever I changed it somehow and therefore when I created new subtasks, the first automation was correctly copying what was there, which was nothing.
When I turned off the second automation, the first one worked. Now I need to figure out how to setup the second automation.
And I figured out how to fix the second automation by using branching. Thank you for the help.
Hi @Craig Wells
I just tried your rule scenario, in a company-managed project, and it worked for me. I included a Re-fetch action after the trigger to confirm the data re-loaded prior to the condition and edit action.
I recommend re-creating the rule from scratch to see if that helps, as rules sometimes get "glitched" and broken from too many edits.
