Automation adding multiple labels at once from a custom field smart value
Harrison Ponce
January 10, 2025 edited
I want to create an automation that adds label(s) when another field is updated. For example, when an asset custom field (can select one or more values) is modified, I want to set the Labels field using the values currently present in the asset custom field. I already have the smart value figured out to get the specific attribute name I want. {{issue.customfield_#####.Attribute Name}} but when it is more than one value, it is trying to add the label with space --> "Asset1 Asset2"
I think I have to use smart values with lists here somehow, and maybe JSON, but couldn't find quite what I needed in the past community forums to pull this off.
Any ideas?
Trudy Claspill
Hello @Harrison Ponce
It will help us help you if you provide us with a screen image that shows your entire automation rule. We can then provide advice tailored to the structure of your rule.
Harrison Ponce
January 10, 2025
It's quite basic at the moment, but I added a screenshot to my original post.
Trudy Claspill
Hello Harrison,
You would need to use Advanced Branching to iterate through the list of assets. See the Advanced Branch and Edit Issues action I created below. Add a Re-fetch Issue Data action to make sure your rule has an updated copy of the edited issue for the next iteration of the branch.
Screenshot 2025-01-10 at 3.36.17 PM.png Screenshot 2025-01-10 at 3.36.37 PM.png
January 11, 2025
Hi @Harrison Ponce
To add multiple Label values based on smart value, please use a JSON edit rather than the Labels field from the dropdown list in the Edit Issue action: https://support.atlassian.com/cloud-automation/docs/advanced-field-editing-using-json/#Labels
To do that, an iterator may be used over the values in the custom field: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-lists/#Combined-function-examples
For example:
"update": {
"labels": [
{{#issue.customfield_12345.myAttribute}}
{ "add": "{{.}}" } {{^last}}, {{/}}
This expression would iterate over the attribute values, with an "add" for each, finally including a comma after each one except the last.
Please add a condition before the edit to confirm the field has a value before attempting the action.
