Automation condition based on comment author membership
matan.grady
I have an automation that runs on each comment.
If the commenter is a specific group member, it has an action.
See screenshot.
The condition is never met.
The same condition works to me in another automation that says " if issue created by membersOf(Support)" and it works.
Any idea?
2 accepted
Vamsi Kandala
February 22, 2023
Hi @matan.grady
Welcome to Atlassian community!
Instead of the 'JQL condition', you can try using 'User condition' and
  • Select the value 'User who triggered the event' for 'User' field'
  • Select 'is in group' for 'Check to perform' field
  • Select the required group for 'Criteria' field
Hope this helps.
Vamsi
matan.grady
Thank you @Vamsi Kandala it worked like a charm!
abelalia87
February 22, 2023
Hi @matan.grady ,
Welcome to the Atlassian community. The JQL condition will search for issues where <field> in membersof(Support). You can try typing in the JQL and you will see the problem with <any user> in membersof(sampleGroup). You can use User condition.  User Condition.png
matan.grady
Thank you @abelalia87 it worked like a charm
