I am trying to run this automation, which should be triggered manually, then prompt for a startDate. That start date should be input into this jql filter query:
project = "Data Management" and summary ~ "dbt Job Run: Test_Center.Test" and issuetype = "Test Execution" and created >= {{startDate}}
This is the failure I get from the audit log:
Manual trigger from issue 02/19/2025, 09:32:28
Create variable 02/19/2025, 09:32:28
JQL condition 02/19/2025, 09:32:28 JQL didn't run, which prevented the JQL condition from passing and its actions from being executed: Invalid JQL: project = "Data Management" and summary ~ "dbt Job Run: Test_Center.Test" and issuetype = "Test Execution" and created >=
I know the issue is around the startDate, but I can't figure out how to fix it. This is the variable: Variable name = startDate Smart value={{userInputs.startDate}}
Any help would be appreciated
Assuming your variable name is: startDate and your input date is 02/19/2025 09:32:28 and you need to use time part, then below will work. / is a reserved keyword for JQL and your date format is giving errors. JQL does not take seconds so that needs to be removed.
if your format was in yyyy-mm-dd format, then it would have worked as it.
project = "Data Management" and summary ~ "dbt Job Run: Test_Center.Test" and issuetype = "Test Execution" and created > {{userInputs.startDate.toDate("MM/dd/yyyy H:m:s").format("yyyy-mm-dd H:m")}}
Apologies for the multiple edits as the time part had to be incorporated as well.
made the updates and still receiving the same error. also updated the startDate
Check with this date 02/19/2025 09:32:28
