×Has anyone found a way to create "sub-rules" for those tasks that are reused in more than one Automation for Jira rule? It would be super useful to be able to call an excerpt/sub-rule that you already have in place instead of having to retype it all.
Hi @David Loszewski - Under rule details, you can select to allow other rules to trigger. If you have a specific example of what you're trying to achieve, please provide it so we can help further.
How would I trigger it though?
Example I have:
During a workflow, once it reaches a certain step, it will create an issue and copy certain fields over from the trigger issue. These fields vary in range from 20 to 50 fields depending on the issue type.
I would like to take "edit issue fields" and either copy it to another automation rule or be able to call it from another rule so I don't have to duplicate my efforts.
Ideally I'd like to take that edit issues fields action and place it into a manual trigger rule and then be able to call upon that rule.
For your example, is there a reason that you're using the Create Issue action vs Clone Issue? My interpretation is that you probably have more fields being copied than not so you could use clone and then explicitly set the exceptions on the fields you don't want copied over. This should make your rule less challenging.
Otherwise, you would want to do something like this:
RULE #1 - Create Issue
RULE #n - Edit Issues
This is where you'd set up your children rules that are allowed to trigger from other rules. They would work something like this:
isBlockedBy = {{issue}}
{{lookupIssues.Field x}}
