Automation for Jira - endWith only matching with Yes and No
Malka
So I am doing a defect matrix and here are some of the things I am trying to check. The ones that check for yes or no are passing, the ones with any other word come back as expecting three elements, but only finding two.
{{#=}}IF({{issue.Application Workflow is Functional?.value.endsWith("No")}},30,0)+ IF({{issue.Does this Involve Data Corruption?.value.endsWith("No")}},0,50) + IF ({{issue.Performance or Speed Related?.value.endsWith("Yes")}},10,0) + IF ({{issue.Compliance Issue?.value.endsWith("Yes")}},30,0) + IF({{issue.Is this a Patient Care Issue?.endsWith("Maybe")}},15,0) + IF({{issue.Is this a Patient Care Issue?.value.endsWith("Yes")}},30,0) + IF({{issue.Impact to Financial?.endsWith("Direct")}},30,0) + IF({{Impact to Financial?.endsWith("Indirect")}},20,0)+ IF({{Impact to Financial?.endsWith("None")}},0,0)+ IF({{issue.Data Not Displaying or Displaying Incorrectly?.value.endsWith("Yes")}},15,0) + IF({{issue.Visual Artifact.value.endsWith("Yes")}},5,0) {{/}}
June 30, 2020
Hi @Malka
Were you able to figure this one out?  I did some checking and I noticed:
  • The function endsWith does not handle empty values or mismatches well.  I got around that by using the default value to support the IF test.  For example,
IF({{somefield.endsWith("Hello")|false}}, 10, 20)
  • In your formula, some things include the issue. reference and others do not.  That should not matter, but who knows.  Same thing for the use of .value
Best regards,
Malka
Those were guesses on the issue. & trial and error on the .value parts.
I do have it working on our instance now. It's made things a lot easier for triaging. I can't wait for intellisense on these things.
Like Bill Sheboy likes this
July 1, 2020
I agree!  Seems like some of these went to the "future consideration" chasm.
https://jira.atlassian.com/browse/JSWCLOUD-20445
https://codebarrel.atlassian.net/browse/AUT-1968
