Automation for each issue
Kevin McGillicuddy
I have a an automation that runs every night at 11:30PM EST which queries a project and finds issue(s) wthat meet the critera. What I want it to do is create a single version then foreach issue found edit the version field to match the created version and then release the version
What is happening is it seems to have run twice?
Here is the query that is scoped to that project
updatedDate < endOfDay() AND updatedDate > startOfDay() AND Sprint is EMPTY and fixVersion is EMPTY and deploymentEnvironmentName ~ “prod“ and status = resolved
Any help would be appreciated
John Funk
Hi Kevin,
It looks like it is trying to create a version for every issue returned in your query.
I would remove the query from the Scheduled trigger part but leave the create version where it is.
Then change your Branch for JQL and put the query there.
Kevin McGillicuddy
that makes so much sense!
For documentation sake I removed the JQL from here and moved to a new branch
new layout:
Kevin McGillicuddy
Thinking more about this - I will need a null check so it does not create a version if nothing was - any thoughts on best way to do this? So I don't want empty versions to be created and released
John Funk
Let me think about that a little more. Maybe using lookupIssues with a count and the count > 0  but I would have to work out the code. That might take a day or two or maybe @Bill Sheboy could help in the short term.
September 27, 2021
Hi @Kevin McGillicuddy and @John Funk
Yes, I agree with John.  Please try this:
  • after the trigger, add an action for Lookup Issues with the same JQL you plan to use in the branch
  • next, add an advanced compare condition to halt processing if no issues are found
    • first value: {{lookupIssues.size|0}}
    • condition: greater than
    • second value: 0
Like John Funk likes this
John Funk
Thanks, Bill!!
Kevin McGillicuddy
Thanks Bill appreciate that will give this a try!
Also do you think then I would be able to change my branch rule (in the second picture above) from JQL, as John suggested, to now be All Created issues? I may play with that in sandbox - basically trying to avoid having the JQL listed twice but its not the end of the world
John Funk
You aren't actually creating issues in this rule, so I don't think the All Created issues would apply. Plus you are running it at 11:30 pm so it shouldn't hurt to hit JQL twice.
Like 2 people like this
Kevin McGillicuddy
Thanks will let you know what happens
Kevin McGillicuddy
this worked perfectly
Register now
