Automation has stopped working
Sergi Ortega
Dear colleagues,
I built an automation that it has always worked. Nobody has touched anything there and it suddenly has stopped working.
It's basically built so: A task that has linked a lot of task as "deploys" goes to a certain status, then all "is deployed with" tasks go as well to the same status.
Here is a picture of the automation, I do not what has happened. I created the automation again but I keep getting the same "Failure message"
Thank you so much for your help!! :)
Sergi
Mykenna Cepek
December 15, 2021
I would take this straight to Atlassian Support, and open a ticket to have them look into it. Be sure to give them permission to access your instance to diagnose it further.
Open a ticket here:  https://support.atlassian.com/contact/#/
Dirk Ronsmans
December 15, 2021
Absolutely, the automation throwing java error's is an underlying issue and not something you can fix/troubleshoot yourself.
Getting the Atlassian engineers involved it the right thing to do here.
