Automation help
Lesa Miller
The following automation:
When: Commit created:  rule is run when a commit is created
Status is one of in Progress
Then: Assign the issue to User who triggered the event
And: Transition the tissue to In Progress.
Assign the issue to:  specify user
Select a user: User who triggered the event
It seems the Assignee is blanked out.  We use GitHub, I don't know if the issue is that our devs don't use our company emails in GitHub or if there is another reason?
March 31, 2022
Hi @Lesa Miller
Short version: I do not believe that is possible yet.
If you wrote the triggering user to the audit log, {{initiator.userName}} I believe you would find it blank.  There is an open suggestion to add user-related fields to DevOps triggers for this use case you asked about: https://codebarrel.atlassian.net/browse/AUT-1997  And here is the related suggestion in the Jira Software backlog which can be watched/voted for: https://jira.atlassian.com/browse/JSWCLOUD-21908
