Automation or bulk update fix version
sarathgd
I have a project with fix version as 1.12, xyz tagged to a release. In my project I have multiple issue types like epic, feature, task etc.
Is there any way I can write an automation rule or bulk update fix version like abc (append to 1.21 & xyz) , at project level ?
Sarat
Sakina
October 12, 2022
@sarathgd  yes you can do it just go to advance search , select your filter criteria t get all issues that you want to update version, from top right menu select bulk update and then follow instruction update fields that you want to updateimage.png
FREE
