Automation rule for sub-task, copy parent component field value
Sierra
June 6, 2022 edited
Trying to figure out how to create an automation rule that sets my sub-tasks component field, the same as whatever parent issue type I'm using has.
This one of the many rules I've tried , am I close ?
3 accepted
3 votes
Mark Segall
Hi @Sierra - You'll need to change the Edit Issue action to copy from Parent
Saurabh.Sharma
Saurabh.Sharma
HI Sierra,
Please try like {{issue.parent.component/s}} . It works for me.
Saurabh
Kat Jansen May 23, 2024
We've got an automation rule like this but it's breaking when the parent has multiple components.
I tried this trick and I get the same error.
Couldn't edit the Components field - the component doesn't exist
No fields or field values to edit for issues (could be due to some field values not existing in a given project):
Here's the Automation Rule:
Any advise?
Like • H Guy likes this
H Guy
November 6, 2024
I have the same problem. if the parent has multiple components I cant get the rule to work with either of these smart values:
{{triggerIssue.components}}
{{triggerIssue.components.name}}
{{triggerIssue.components.name.join(", ")}}
{{issue.parent.components.name}}
{{issue.parent.components.name.join(", ")}}
Someone please help!
