Automation rule to add to Next Gen Active Sprint
Fowler
The answer provided to this question: JIRA Automation Set Active Sprint, is exactly what I am looking for, however, it only works for traditional (non-next-gen) projects.
I want to implement the following:
When marking an issue in my Next Gen project as "In Progress", the `Sprint` field should be set to the currently Active Sprint.
Yvan Martin
June 10, 2020 edited
Hi there Fowler,
Developer from Automation here.
I've just tested the same scenario and had no issue editing/creating issues with the active sprint set from a next-gen project. Can you confirm this is the case, and what exactly is or isn't happening instead?
You'll need to ensure that you created a nextgen project with a scrum board (doesn't work with kanban), and you'll need to start a Sprint first if you haven't. Make sure to refresh the page after running the rule if you haven't, and you can find any success/error information in the audit log section after clicking "show more" on the failed execution.
As a note the sprint field only works with scrum projects with a board, not kanban.
If you are still having problems getting your rule to work then it might be worth contacting support for further help with your issue here: https://support.atlassian.com/contact/
Screen Shot 2020-06-11 at 10.20.59 am.png Screen Shot 2020-06-11 at 10.20.49 am.png
