Automation rule to fill original estimate field
Malavika L P May 3, 2022
I wanted to set an automation rule where the original estimate field gets automatically updated if I enter a value to the story point field
For example: Story Point = 1 my Original estimate field has to be updated as 8h
5 votes
Jorge Martinez
May 3, 2022
@Malavika L P this automation works for me
Please replace the '480' with the value in minutes that you need for each Story Point.
{{#=}}{{issue.Story Points}} * 480{{/}}
@Jorge Martinez Thanks a lot it worked for me as well :-) you really helped me
Ed Gaile _Atlanta_ GA_
Extremely basic automation to get you going (based on the requirement).
You may need to add in additional logic to handle different Story Point conditions.
Jorge Martinez
May 3, 2022 edited
How are you calculating the original estimate?
@Ed Gaile _Atlanta_ GA_ the one suggested worked for me..thank you for your support
Michael Marriott January 31, 2024
OK but how about monitoring the 'Original Estimate' field. It does not seem to be available in the list of fields.
Ravi February 6, 2024
Ravi February 8, 2024
Hi @Mich , I've managed to find the link which can calculate the sum of original estimates of all issue types to an Epic using the Jira Native Automation capability
https://community.atlassian.com/t5/Jira-Software-articles/Calculate-the-sum-of-original-estimates-of-all-issue-types-to-an/ba-p/1660572
Register now
