Automation rules not sending email to specific group
Sarah Noor August 17, 2022
I have added an automation rule that is configured to send and email to a jira users group within my organization whenever a specific field value is updated. I have tried to make it work with single email as well as group but it won't send emails in any case. What can be the issue here?
Alex Koxaras -Relational-
Hi @Sarah Noor and welcome to the community,
Can you please share an image of your audit log? Is your rule successful or not? Does your rule get triggered or not?
I tried your rule and it worked perfectly. The only difference I see, is the "product" you have on your send email. Is that a role?
Sarah Noor August 18, 2022
@Alex Koxaras -Relational- my rule does not get triggered hence no audit log.
"Product" is a group that i have created. Are you sending to a specific email or the initiator who performed the action?
@Alex Koxaras -Relational-  are there any specific email settings that you have set up for the project or the organization in jira ?
@Sarah Noor if your rule doesn't get triggered, then that's your problem. Your trigger is "when value change" for the Release Date field.
  • Kindly check that all issue operations are included in the trigger
  • You have selected the correct field (check if you have multiple fields with the same name)
  • Check that the rule applies to the specific project
Like • Sarah Noor likes this
So turned out that the field was edited(just the name change) and it wasn't being reflected properly on the automation page for fields dropdown. This seems to be an issue on Jira's end for which i am going to open another ticket.
For now, i deleted the field and added it again and updated the rule with new field and it worked.
Thanks for the help all.
Like • 2 people like this
John Funk
Hi Sarah - Welcome to the Atlassian Community!
Can you share the details of the Send Email step?
Also, can you share the Audit Log?
There is not audit log since the rule never got triggered.
Here are the details, i am trying to send email to a group named 'product'. Also tried with a single specific email and that did not work either.
John Funk
Since it didn't get triggered, check the Rule Details page and check the box that says "Allow rule trigger". Then save and publish and give it another whirl.
Samuel Gatica _ServiceRocket_
Hi  @Sarah Noor
Can you please share with us the log errors from the rule?
Regards
Sam
there are no errors as the rule is not triggered.
atlassian, team ’25 europe guide, teamwork collection, atlassian events, conference guide, team culture, collaboration tools, ai in teamwork, atlassian learning, event schedule, keynote previews, community events
Must attend events for Team Europe '25!
Make the most of your time in Barcelona with our curated guide – discover how Jira, Confluence, Loom, and Rovo work better together, connect with Atlassian experts, and enter to win an Apple prize bundle!
Get the guide
