Automation rules with custom fields
Tim Ballingall June 26, 2024
Hi
I am playing around with automation at the moment and cant seem to find a solution to a specific use case i am proposing.
I am sharing a single custom field across several project types, with this custom field locked to a dropdown list of known values.
To make it easier to use, and make the process less prone to human error, I would like this custom field to be filtered based upon either a Project Name or Project Type.
So, if a User selects "project A", then I would like this custom field to be limited to items "A,B or C".
If the user selects "Project B", then I would like this same custom field to be limited to items "X,Y or Z"
I am using the custom field to help with management and analysis of issues
Is this possible ? seems to be a bridge too far from what i can see in the automation builder
thanks
t
Melo
Hi @Tim Ballingall, to show different options depending of the project you may want to look into the custom field Context instead of automation.
https://support.atlassian.com/jira-cloud-administration/docs/configure-custom-field-context/
I hope this helps.
Melo
Thanks so much - perfect !
