All,
I'm trying to map Priority and a custom field based on the value in Priority through JIRA automation, need help on mapping a select list.
Field1: Priority (Single select with values P0,P1,P2,P3)
Field2: Dept Custom field (Single select with values A,B,C,D)
___________________Mapping______________
If Priority value is set to: P0 then Set the Dept value to : A
If Priority value is set to: P1 then Set the Dept value to : B
If Priority value is set to: P2 then Set the Dept value to : C
If Priority value is set to: P3 then Set the Dept value to : D
Any input on the JSON script to map the above would be appriciated.
You can do this by simply using the if/else condition, no need to create a JSON script to map it. The if/else would look something like this:
What if I want to use a dictionary to create a mapping ? I have a similar situation but with a hundred of different values, it would be much easier for me to maintain de dictionary rather than add a bunch of "ifs".
