i've created rule : if today-due.date = 4 send e-mail notification to:
assigned and reporter works perfectly
BUT
I would like to send it to watchers or users specified in the custom field - any idea how to do it? Please?
Have you tried to enter the smart value in the email TO field?
I found that if you type the field's smart value, e.g. {{issue.myCustomField}}, you will be prompted to enter the smart value. Just click on the prompt and it will add it to the TO field.
Best regards,
thx for reply. I thought about it, but:
I was hoping there is an easy way to use watchers list.. didn't find.
Hi, Emilia.
If the people you want to notify are watchers, you could try this one:
{{issue.watchers.emailAddress}}
As with the custom field, type that into the email TO field. I just tried it and it worked for me to notify watchers. I found that smart value on this documentation page:
https://support.atlassian.com/jira-software-cloud/docs/smart-values-general/
