Automation that clones an epic with all its stories and tasks
Michelle Herschell
I am trying to create an automation that clones an epic and all the stories under the epic, AND all the sub-tasks underneath the stories... is that possible to have all in one automation?
This is the automation so far. Cloning the epic and stories works, it's the sub-tasks part I need help with.
Trudy Claspill
Hello @Michelle Herschell
There are several posts on that topic in the communities. Have you searched for and reviewed those?
Here is one such that has an accepted Answer:
https://community.atlassian.com/t5/Marketplace-Apps-Integrations/Automation-for-Jira-Clone-Epic-Story-and-Sub-tasks/qaq-p/1719652
And here is an article from an Atlassian Team Member:
https://community.atlassian.com/t5/Jira-articles/Clone-Epic-Stories-and-Subtasks-tree-with-Jira-Automation/ba-p/2316387
Syed Majid Hassan -Exalate-
July 29, 2023
HI,
This is Majid @ Exalate.
There are two high level approaches to solving this problem i.e. automation rules or an integration app such as Exalate. Both approaches have their pros and cons, but with an integration app you can do much much more than just copy these Epics over. All depends on what you need.
Hope it helps.
Majid
Luka Hummel - codefortynine
Hi @Michelle Herschell
If you are willing to use a third-party app, our Deep Clone for Jira is able to clone whole hierarchies including Initiatives, Epics, Task, and Subtasks.
The app is highly configurable, and you can even set your field values dynamically while cloning with Clone and Edit.
Thibaut Subra _Elements_
July 13, 2023
If you're not against using a third-party, you can do that with our Copy & Sync application with the option "Copy Full Epic Tree". It will clone (and synchronize if you choose to) the Epic, its children and all their subtasks with everything you need it.
And you can do that in just one rule as you just have to set your Automation with the required conditions, then use a Copy & Sync recipe to do the work.
Let me know if you need help with that!
Regards
Evgenii
July 12, 2023 edited
Sorry, my previous answer was not correct. Without additional JQL functions it's not working.
@Trudy Claspill +1 to her answer, it will work :)
Evgenii
Well, it's very draft variant. I'll try to make normal example
atlassian, state of product 2026 webinar, product team report, webinar, product management, ai productivity, agile practices, team alignment, product report, atlassian learning, product strategy, discovery to delivery, survey insights
Webinar: State of Product 2026
We asked real teams how they’re coping with an industry in flux. Join this webinar to hear the research –plus tips for leveling up your team’s work.
Register now
