Automation to Send an Email when a Field Value is Assigned
Kevin Paul
I need to create an Automation when "Product Team" is Assigned to "Mobile".
How do I do that?
3 accepted
Vando Goncalves _e-Core_
Hi Kevin!
I'm assuming this "Product team" field it's a custom field, right?
Considering that, you just have to set an automation with the "When" as Value changed, and possibly adding a IF new value equals Mobile, Then send an email.
Hope this helps, and will be glad to help if you have more questions...
Kevin Paul
Hi Vando,
Yes, it is a Custom Field and I have now Setup the Automations as below.image.png
Heryclles Henrique do Nascimento June 30, 2023 edited
You can create an automation rule with the trigger field changed, just select the "Product Team" field and create an if field value equal to "Mobile" and add a step to send email.
Markus Fredén
June 30, 2023
Hi @Kevin Paul
Have You tried setting up the rule? What issues did you face?
I would assume it would look something like this;
WHEN-> "Field Value Changed" (Product Team) -> IF -> Product Team = Mobile -> THEN...
Here's the official documentation:
https://support.atlassian.com/cloud-automation/docs/create-and-edit-jira-automation-rules/
/Markus
Kevin Paul
Hi Markus,
Thanks for Replying
How Do I add the IF Condition?
Markus Fredén
June 30, 2023
That's exactly it, JQL condition "Product team" = Mobile.
It should work the way you've set it up. Just need to add the action.
Best regards,
Markus
Kevin Paul
Thank you!!
I have added the Action now.
I will monitor it and get back to you.
Thanks for your help.
Like • Markus Fredén likes this
Read the story
