Automation to display all users selected in a multi-user picker custom field
Darwin November 15, 2022
Hi there,
I am trying to make an automation to comment on the issue and cc the users selected in the custom field "Point of Contact" (multi-user picker).  Whenever i try to use
[~accountid:{{Point of Contact.accountId}}] it will only work when i select one user, but if i select more than one user it will display "User" in the automated comment.
This is also the case for:
[~accountid:{{issue.Point of Contact.accountId}}]
November 16, 2022 edited
Hi @Darwin Fernandez -- Welcome to the Atlassian Community!
As your field is multiple-select, the smart value is a list of values.  Try using an iterator to walk them, for example here is the list of mentions with comma delimiters:
Hello to the points of contact:
{{#issue.Point of Contact}}[~accountid:{{accountId}}]{{^last}}, {{/}}{{/}}
Here is an update for you...
Darwin November 18, 2022
Thank you! This works well.
Like Bill Sheboy likes this
Alexander Ziegltrum
Hey @Bill Sheboy 👋
thanks a lot as well😊 That helped me, advancing an automation for project generation and assigning users from a user picker field into a role into the people of the project.
Cheers, Alex
Help us plant more trees
