×Hi!
We need to create an automation that whenever an new issue is created it checks for issues with the same summary, and then it links the new issue to all issues with the same summary.
We´ve already checked the forum answers below:
Solved: Automation JQL condition: using smart values (atlassian.com)
Solved: Jira automation - link issues with same field valu... (atlassian.com)
It didn´t solve the issue we´re facing.
Here is our current automation:
When we run it, the automation log registers the following:
It seens like the JQL and branch rules are okay, but the link simply does not work, as nothing happens.
If we change the link rule to {{issue.summary}} we then get the following result:
Does anyone has any idea about how to fix it?
Hi @Igor Seidl
Perhaps beyond the scope of the permissions issue you are observing, there are some other things to note:
First, the Issue Created trigger can fire so quickly that some issue data may not yet be available to the rule. This can cause missing data and mysterious errors, such as permissions ones. The fix for that is to always add the Re-fetch Issue action immediately after the Issue Created trigger, and before other rule steps. This will slow down processing a bit and reload the data before proceeding.
Next, your rule is using JQL with the CONTAINS ~ operator: https://support.atlassian.com/jira-software-cloud/docs/jql-operators/#CONTAINS----
What do you mean by "checks for issues with the same summary"? Do you mean:
As your rule is shown, the CONTAINS operator will do the first one. To perform an almost exact match, use the exact phrase syntax in the rule:
summary ~ "\"{{triggerIssue.summary}}\""
Escaping the quotation marks around the value will try for the exact match...however that could be led (or followed) by other text. For example, if the trigger issue summary was, "this story is about squirrels", it would match the following summaries:
You could adjust your rule accordingly if you truly need an exact match of the summary:
Hey @Igor Seidl
Your automation looks good to me, do you have anything setup in Issue Security for this project? From the looks of the Audit log this might be the issue.
Hi @Jack Tucker , thanks for the response.
I tried to create a new issue security scheme:
But I was unable to connect it to the specific project (in this case, "Cobranças"). I tried to make this new security scheme the "default" but when I run the automation, I still get the same result:
It´s officially a sucess, but nothing happens and no issue is linked to another. What we need is to link the newlyl create item (in the case, the CRC-3077 one) to others with the same summary (in the case, the issues CRC-3074, CRC-3075 and CRC-3076).
@Igor Seidl - If you go to the Project > Project Settings > Issue Security, can you see any issue security applied to the project?
Am thinking you might need to add "Single user (Automation for Jira)" if you have issue security setup in the project.
Hi @Igor Seidl
Welcome to the community!
Try using the Branch rule "Similar issue description" this will look for Summary and Description and you can adjust the similarity!
I hope this helps!
Best regards
Sam
Thanks for the idea @Samuel Gatica _ServiceRocket_ , but it didn’t work.
The description field isn’t what we want to check (we need the same summary), but it was worth testing. Unfortunately, it didn’t work.
Hi @Igor Seidl
The Branch rule "Similar issue description" will look for a match in the Summary or Description.
Can you please upload the Automation details?
Best regards
Sam
Hi! thanks for the clarification.
The automation is:
And the audit log when after adding a issue with the exact same summary of the previous is:
But it results in nothing. No issue is linked, nothing changes in any issue.
Hi @Igor Seidl
In the image uploaded, you are using the JQL branches, instead, change this to the Branch rule "Similar issue description" and then update the similarity to your best convenience. Please follow the example in my first comment.
Best regards
Sam
Hi, I just did it like you suggested with 2 different similarities and in both cases the search fails to find more issues with the same summary (and all cases had the exact same summary) and to create any link.
Similarity: similar
Automation:
Audit log:
Similarity: Very similar
Audit log:
Register Now
