Hi :)
I have an Automation between Jira Software and Jira Products discovery.
This automation checks for bug tickets in the development board that are in the active sprint and adds them to an idea in Jira Product Discovery to represent the work on bugs in our roadmap in product discovery.
Therefore it adds the bugs as deliveries to the idea in product discovery.
For that I used the Edit issue action with following code:
"update":{
"issuelinks":[
"add":{
"type":{
"name":"Polaris issue link",
"inward":"is implemented by",
"outward":"implements"
"outwardIssue":{
"key":"REQ-607"
But now I need the same thing to remove the issue link again because I always want to use the same Idea in JPD which gets updated automatically but not filled up with hundreds of bugs. As soon as the bug is done and the sprint ends this bug should be removed from the idea as the delivery ticket.
I tried to use "remove" but it doesnt work.
I think you need to use "Delete", see api documentation.
i guess i cant do that where i am creating the automation it says only available is the operation add or copy
I think, I might have found you a workaround, see Remove-link-using-JSON
Yeah I found this too. But as it is said there. It will cause a lot of changes. I just dont get why there is no delete or remove operation available there. But ok. Hoped there is an easy solution.
Thank you :)
Register now
