If I go into the zephyr squad suite and create a test cycle under a release and I try to add tests individually, they all fail.
Hello @Krishna Dass , fix for this issue has been deployed. Could you please check if it is working fine for you.
Hi @Sanjeev Pande , thanks for your quick turn around on this issue. Tested, works well. Thank you :)
We, at Zephyr Squad are looking into this issue on top priority. Will update you soon when this issue will be fixed.
Thank you.
