Hi @Ravina
You can create Scriptrunner Listener:
Condition:
issue.priority.name == "High"
Code:
def resp = put("/rest/api/2/issue/${issue.key}")
.header('Content-Type', 'application/json')
.body([
fields: [
description : 'Description for issues with high priority'
.asString()
assert resp.status == 204
Thanks, I am able to change the description.
Hi @Ravina
You can accomplish that either by using Jira Automation, or by workflow automation on the create transition.
Alex
Post your script please and the results you are getting
Save your spot
