Best Language for Jira Cloud Rest API's
seethamraju
Hi Team,
I would like to learn Jira cloud rest API's so i recently visited to Atlassian documentation, where i found programs are available in 5 languages like (cURL, NodeJS, PHP, Python, Java)
Out of all these languages can any one suggest which is best and most used one.
Thanks in advance,
Raju
Nic Brough -Adaptavist-
April 21, 2020
I wouldn't worry about the language, it really doesn't matter.
Purely as an academic exercise, I wrote a bash script that took a url constructed by a program written in Ook! as an input to a curl call to a Jira REST API that created a new issue.
I would not recommend that, Ook! is not a lovely thing to try to code in.
You should code in whatever you want to.  From your list, I personally would use Java, but that is purely because I know enough Java to do what I want.  I've not used Python enough to form an opinion, but I know plenty of people who love it, and count people whom I have a lot of respect for amongst them, so there must be something in it.  I'd say the same about Javascript too.
Lasse Langhorn
April 21, 2020
I would go for Python if I were to recommend a programming language. It is very powerful and you can find Python packages for almost anything.
As Java and Python programmer I found the Python language to be extremely flexible.
I would recommend a Python package like Atlassian Python API or Python Request. I have used both packages when I were to manipulate the Atlassian REST API on Atlassian instances like Jira, Confluence or Bamboo.
Hope this will get you started.
Regards
Lasse Langhorn
