Best way to organise test cases in Test Plan with multiple testers
rsharma2
Hi All,
What do you recommend is the best way to organise tests in a Release Test Plan when there are multiple users who are going to perform testing?
I have created a Test Plan and thinking of creating multiple Test Executions one per tester and then add test cases from Test Repository to each Test Execution but not sure if that's the most efficient way to do it.
Please advice. Thanks.
