BigTemplate not working
WK46 November 11, 2022
Hello Community,
I have a lot of problems with BigTemplate.
1. I can not configure Bigtemplate, I click on the option and then starts an endless loading screen.
2. when I want to export the Gantt in BigPicture, it also only opens an endless loading screen
Unbenannt.PNG 3. when I want to export the scope, I get the error message
"This functionality requires BigTemplate to be installed.
Make sure it is enabled and your license is still valid."
BigTemplate is installed and also has a valid license.
BigPicture and BigTemplate are up to date
I hope to find someone here who can help me
Sajin Antony November 15, 2022
Do you found a solution? I have the same problem
WK46 November 15, 2022
hi @Sajin Antony , unfortunately i don't have a solution yet, but i have contacted the developers and they are now trying to find a solution...
Dirk Ronsmans
hey @WK46 ,
For these type of issues you might want to reach out to them directly. You can raise a support issue at https://jira.softwareplant.com/servicedesk/customer/portal/1
thx for the Link
