Block Issue Creation if Condition Met
Cyan Lee January 28, 2023 edited
I am using Jira Software.
I want to prevent an issue transiting from 'create' to 'to do' if the following condition is met (in JQL). Can I achieve this without any marketplace plugins? If so, how please?
project = BPO
AND
created >= 2022-11-02
AND (
"Select one ticket type[Select List (cascading)]" in cascadeOption(10522, none) OR
"Select one ticket type[Select List (cascading)]" in cascadeOption(10532, none)
OR
"Select one ticket type[Select List (cascading)]" in cascadeOption(10623, none)
OR
"Select one ticket type[Select List (cascading)]" in cascadeOption(10325, none)
OR
"Select one ticket type[Select List (cascading)]" in cascadeOption(10176, none)
3 votes
Ravi Sagar _Sparxsys_
January 28, 2023
Hi @Cyan Lee
Out of the box following conditions are available.
Looking at your question I don't think you can achieve that without an app. You can use "User is in a Custom Field" and "Value Field" conditions to achieve some of your logic if not all.
Ravi
Thanks Ravi for your kind advice.
Kelly Arrey
January 30, 2023
Another approach might be to use Jira Automation to set a flag in the labels field, and then check that flag in the workflow transition.
