Hello Dears;
Is there a way to create a board filter with a drop-down list, or with an input field??
I have a project with 9 developers, and I want to create a board filter to show each developer's tasks, without creating nine filters!!
I know I can use the advanced search and specify the assignee, but the search interface does not show the status of the issues.
Thanks in advance.
Ibrahim
There is an easier way for all of you to do that. Just below your kanban title, there are some avatars. Each user will see HIS/HER avatar first in line. If they press it, they will only see their issues.
This is what I strongly recommend. Other solutions would be:
Let me know if that helps.
Thank you @Alex Koxaras -Relational- for your thoughtful reply
In fact, I have been using Jira for 4 months, from beginners into advanced features (transition permissions, automation, a little JQL...) but did not notice these avatars till today.
Thanks again,
Ibrahim
