Boards for Service Management project
Sofia Quintero
Acording with the documentation, a service management project is able to have a board. But this was possible if you create from boards menu on the top bar.
How ever, this option on the bar no longer exist. How do i can create a board for a SM project ?
2 accepted
Rik de Valk
I usually add a Project link to the Board so that you have an easy and quick link to access the Board directly from the Project
Sofia Quintero
Great idea, thank you!
Benjamin
Hi @Sofia Quintero ,
Correct. It is not the same path as before. If you go to one of the Jira Soft ware projects, you should be able to create a board there.
Select the SM project and have this place in your personal space. Boards can only live in 2 places: software project or personal space. From that point, you can see jira boards under your profile and create as many as you need across various SM type projects.
Ben
Sofia Quintero
@Benjamin thank you for answer.
So it´s no longer able to link a board with a SM project?
Benjamin
@Sofia Quintero - You can link a board to the SM project. You just will find the board under your profile or icon on the right instead of the tab on the horizontal navigation.
Like • Rajesh Viswanathan likes this
Sofia Quintero
Thank you @Benjamin
Rajesh Viswanathan
I generally create the link and share to my team for easy access
