Bulk Clone
Maya Arad May 3, 2021
does the bulk clone is part of the premium package?
is there a way to execute it without the plugin?
thanks,
Maya
John Funk
Hi Maya - You could also use the Deep Clone add-on.
KAGITHALA BABU ANVESH
May 3, 2021
Hello @Maya Arad ,
Without a plugin in,
You can export the selected issues into .csv format.
Remove issue Key from the .csv file and import them.
Please check the below link.
https://support.atlassian.com/jira-cloud-administration/docs/import-data-from-a-csv-file/
Anvesh
