Hey Team,
One of our products has a set release schedule for the entire year. Rather than creating each one of these Fix Versions manually in Jira - is there a way to import them in bulk? Each of them has a:
Appreciate any help!
Hi @Eric Taylor and thanks for your question.
You can following link might help.
Hope this helps. If the issue is resolved, you can vote and accepted for this comment.
Best,
Murat Seven
Thanks @Murat Seven for your reply. I saw that post earlier. The problem with that is it requires you to first manually create all Fix Versions first. I want to bulk-load new Fix Versions with all the details.
