Bulk delete Custom fields in Jira cloud
Preethi Srikakula January 29, 2021
Post migration we have ended up with unwanted custom fields which were part of default field configuration .
Is there a way I can bulk delete Custom fields in Jira cloud ?
Preethi Srikakula January 30, 2021
How about I use scriptrunner script to delete unwanted custom fields . I found this info about Customfieldmanagerinterface and there is function "removeCustomField(CustomField customField) " Can i use this in loop and delete?
https://docs.atlassian.com/software/jira/docs/api/7.6.1/com/atlassian/jira/issue/CustomFieldManager.html#removeCustomField-com.atlassian.jira.issue.fields.CustomField-
Darryl Lee
January 30, 2021 edited
Hi, I love the idea of using Scriptrunner (especially if you have it), but I don't think that'll work.
The API you reference is for server, but even more importantly, it's an internal API. Scriptrunner on Cloud can only talk to REST APIs.
And from this bug, it appears that there is no REST API for deleting a custom field: https://jira.atlassian.com/browse/JRACLOUD-28539
However, I just tested the CLI command I posted above, and it worked, so I have to assume that @Appfire Support is using the undocumented APIs/endpoints that @Peter Majeed discovered and documented in that ticket:
Below are some workarounds I found useful as of 2020-11-17.
There's an undocumented REST API for trashing fields.
POST https://your-company-name.atlassian.net/rest/api/2/field/customfield_xxxxx/trash
Once you trash a field, it will be deleted after 60 days. To permanently delete the field, not sure if there's a REST API, but Jira currently uses an undocumented jspa page to do this. You will need a token from the browser to execute this request.
POST https://your-company-name.atlassian.net/secure/admin/DeleteCustomField.jspa
FormData: id=xxxxx&Delete=Delete&atl_token=browser_token
Bottom line: I don't think you'll be able to do it with Scriptrunner, but... it wouldn't cost you anything to try it with CLI.
For reference, here's a transcript of my testing session:
$ acli --action removeCustomField --field "Multi"
Custom field 'Multi' removed. Field had id customfield_10078.
I'll note that the field was deleted. It does not show up in the new "Trashed" tab for Custom Fields. (Hey @Appfire Support that might be a nice feature to offer.)
Preethi Srikakula January 31, 2021
Thanks @Darryl Lee  for detailed explanation and help . Will try out the CLI as suggested .
Perry Tancredi
3 votes
Darryl Lee
There's no way to bulk delete custom fields within Jira itself.
But you could put together a shell script/batch file that uses Atlassian CLI to run several removeCustomerField commands:
https://bobswift.atlassian.net/wiki/spaces/JCLI/pages/1059398143/removeCustomField
Example (after you've installed and configured it. By the way, I highly recommend setting up a configuration property file):
acli --action removeCustomField --field "Field You Don't Need" --continue
acli --action removeCustomField --field "Another Field You Don't Need" --continue
acli --action removeCustomField --field "Unneeded field" --continue
Bob Swift {Appfire}
fyi... the --continue on the removeCustomField action is just a way to ignore a not found error so you can run your script multiple times if needed if you add more fields later when testing.
Also, a slight improvement would be a single command:
acli -a runFromList --list "Field You Don't Need, Another Field You Don't Need, Unneeded field" --common "-a removeCustomField --field \"@entry@\" --continue"
Note: use "" instead of \" to do escaping on windows.
Like • 3 people like this
Rodolfo Romero - Adaptavist
There are now 2 REST endpoints that allows you to get the list of custom fields in the trash, and delete them.
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issue-fields/#api-rest-api-3-field-search-trashed-get
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issue-fields/#api-rest-api-3-field-id-delete
A python script can be quickly implemented to 1) get the list in the trash and; 2) iterate over the list to delete each custom field.
Pramodh M
Hi @Preethi Srikakula
This feature is not available yet.
The request is open here, https://jira.atlassian.com/browse/JRACLOUD-37773
Pramodh
Thanks Pramodh
Rob Horan
June 9, 2022
Need this now...
Learn more
