Burn down Chart for Timetracking Issue
maximilian.lieder June 8, 2023
Hello.
I have a Jira Project with several Timetracking Issues.
In the dashboard i can create a burndown chart for the entire project.
What I am looking for is the possibility to create a burn down chart for each single timetracking issue.
Is this possible?
Thanks in advance
Cheers Max
Danut M _StonikByte_
Hi @maximilian.lieder,
Why would you create a burndown chart for every issue? The burndown is usually for the entire project, team or sprint...
Anyway, you can do this by using the Release Burnup Burndown Chart gadget offered  by our Great Gadgets plugin. This gadget is based on a filter, so you can create a filter that returns only one issue and then add the gadget to the dashboard and configure it to use that filter. Assuming that you do not have so many issues to track, repeat this for every issue.
Release Burndown Chart with forecast
The gadget supports calculation by time estimate / tracking and allows including the subtasks in the calculation.
This app offers many other gadgets that you will find useful.
If you have questions, please contact us at support@stonikbyte.com.
Thank you,
Danut M.
