We've just started a new sprint and have decided that we want to use Time Tracking based on Remaining Estimate and Time Spent.
The sprint was created, issues added to the sprint with original time estimates and it was started yesterday. The developers have been logging their time and updating the remaining time estimate as they go along and setting it to 0 once they have completed the issue. The issue is then moved to the Close column on the board.
The burndown chart is however not representing this information. I am just getting two horizontal lines (one red and one green). What have I set up incorrectly?
This is a snippet of the actual burn down chart
image2015-6-16 11:46:37.png
This issue seems to have fixed itself. The time that was not appearing was 'magically' recorded later that day at midnight (not manually). Now, any time logged is appearing immediately.
Estimate Statistic was Original Estimate and Time Tracking was Time Spent & Remaining Time
Did you check the "Refresh Interval" for the gadget? I typically set gadgets with frequent or dynamic data changes to a shorter interval, and data points that rarely change to a longer interval (or never).
Hi Brian,
Thanks for the quick response. Here is another snip of the info from below the chart. The issue seems to be that when time is logged against the issue (and the remaining estimate is changed), it is not appearing in this table. When I manually modified the remaining estimate, the change appeared (last lines). If it is of any help, we have the tempo plugin installed and we use that for our time tracking as well
image2015-6-16 13:44:47.png
Hi Fayez,
This could be due to a multitude of reasons. I would recommend taking a look at the documentation for the Burndown Chart and see why it's not burning down the way you'd expect it to. Looking at the documentation you should see information about the burndown below the chart. Is this not coming up? I'd open up a cloud support ticket and have them take a look at the configuration.
