C# Atlassian Jira library not working with Users since GDPR
ad
June 18, 2022
using NET6 framework with Atlassian.Jira 13.0.0 My Problem is that I can't assign a reporter, when trying to create a new issue, because the "old" style with username is deprecated because auf GDPR strict mode.
Assigning the AccountId don't work and Searching for User isn't working any more, too.
enter image description here
: 'Response Status Code: 400. Response Content: {"errorMessages":["The query parameter 'username' is not supported in GDPR strict mode."],"errors":{}}'
The documentation don't seems to handle user assignments (without using username).
Now the question is if I can (and how) use the Library.
Search isn't working, too: "The query parameter 'username' is not supported in GDPR strict mode"
Also not possible to assign ReporterUser directy: "public JiraUser ReporterUser { get; private set; }"
Register now
