Using the data set below I'm unable to get epics, tasks, and subtasks linked together during import to a next gen board. I'm getting no warnings or errors and everything imports.
However:
1. I cannot see subtasks linked to tasks
2. I cannot see tasks linked to epics
3. and since subtasks are not linked to tasks i cannot see subtasks at all in the next gen board and only through filtering.
Very frustrating and time consuming if anyone can assist i would greatly appreciate it!
Epic Name | Epic Link | Parent Id | Issue Id | Issue Type | Summary | Due Date | Start Date |
Contract Transfers | Epic | Contract Transfers | 1/31/2022 | 3/2/2022 | |||
Contract Transfers | 101 | Task | Copier Contracts | 12/15/2021 | 1/14/2022 | ||
101 | 1011 | Sub-task | Identify/Validate list of copiers by division | 9/1/2021 | 10/1/2021 | ||
101 | 1012 | Sub-task | Work with Ricoh to transfer billing | 12/15/2021 | 1/14/2022 | ||
Contract Transfers | 102 | Task | Data Circuit Contracts | 11/1/2021 | 12/1/2021 | ||
102 | 1021 | Sub-task | Identify/Validate list of data circuits | 9/1/2021 | 10/1/2021 | ||
102 | 1022 | Sub-task | Contact Carrier to request change of owner form | 10/1/2021 | 10/31/2021 | ||
102 | 1023 | Sub-task | Submit owner change form to carriers | 11/1/2021 | 12/1/2021 | ||
Contract Transfers | 103 | Task | Ring Central account | 12/15/2021 | 1/14/2022 | ||
103 | 1031 | Sub-task | Discuss transition of configuration to QUES account | 9/1/2021 | 10/1/2021 | ||
103 | 1032 | Sub-task | Engage Ring Central to assist with moves | 9/15/2021 | 10/15/2021 | ||
103 | 1033 | Sub-task | Review and sign RC SOW | 10/1/2021 | 10/31/2021 | ||
103 | 1034 | Sub-task | Complete transition of RC accounts | 12/15/2021 | 1/14/2022 | ||
Contract Transfers | 104 | Task | Security Systems | 12/15/2021 | 1/14/2022 | ||
104 | 1041 | Sub-task | TotalConnect Security Systems | 10/1/2021 | 10/31/2021 | ||
104 | 1042 | Sub-task | Create new contract and account with Total Connect | 12/1/2021 | 12/31/2021 | ||
104 | 1043 | Sub-task | Migrate services to new contract | 12/15/2021 | 1/14/2022 | ||
Contract Transfers | 105 | Task | Mobile Solutions | 12/15/2021 | 1/14/2022 | ||
105 | 1051 | Sub-task | Identify mobile devices that need to be transitioned | 12/1/2021 | 12/31/2021 | ||
105 | 1052 | Sub-task | Have Mobile Solutions create a new bucket | 11/1/2021 | 12/1/2021 | ||
105 | 1053 | Sub-task | Submit list of phone numbers to M.S. to move | 12/15/2021 | 1/14/2022 | ||
Contract Transfers | 199 | Task | Post Transition Cleanup/Validation | 1/31/2022 | 3/2/2022 | ||
199 | 1991 | Sub-task | Validate transition of Mobile Solutions accounts | 1/31/2022 | 3/2/2022 | ||
199 | 1992 | Sub-task | Validate billing of Security Systems | 1/31/2022 | 3/2/2022 | ||
199 | 1993 | Sub-task | Validate billing of Ring Central account | 1/31/2022 | 3/2/2022 | ||
199 | 1994 | Sub-task | Validate billing of Data circuits | 1/31/2022 | 3/2/2022 | ||
199 | 1995 | Sub-task | Validate billing of copiers | 1/31/2022 | 3/2/2022 | ||
Active Directory | Epic | Active Directory | 1/31/2022 | 3/2/2022 | |||
Active Directory | 201 | Task | AD OU Structure | 8/31/2021 | 9/30/2021 | ||
201 | 2011 | Sub-task | Contact IT for OU Architecture | 8/1/2021 | 8/31/2021 | ||
201 | 2012 | Sub-task | Define dual OU Architecture | 8/15/2021 | 9/14/2021 | ||
201 | 2013 | Sub-task | build out OU Architecture | 8/31/2021 | 9/30/2021 |
Hi again @Jared Lindquist ,
The format you supplied in your table above looks correct. I wonder if "Contract Transfers" and "Active Directory" already exist as epic names in your application? Were there any errors returned by the importer or in the "detailed log" file supplied by the importer?
During my tests, (it only took me 6 tries to get it working, LOL) I noticed that sometimes there was no error nor was an epic link relationship actually established.
The example below works for me in Jira Cloud with a Classic/Company-managed project however.
Here's the format to use for the Epic and parent (Story, Task, etc.) relationship.
Image explanation:
Tips:
Hope this helps!
Rachel Wright
Author, Jira Strategy Admin Workbook
Hi @Jared Lindquist , I think the trouble is the way your "Issue ID" and "Parent ID" columns are structured. In my example below, the "Issue ID" field for the Sub-tasks is purposely empty. Try changing that in your CSV file and let us know if the parent/child linking works.
Image explanation:
Hope this helps!
Rachel Wright
Hi Rachel, thanks so much for this. It worked very well for linking the tasks and subtasks but not the epics. Do you have any suggestions regarding that?
Hi @Jared Lindquist this worked for me fine even though the validator said the sub-task would not be imported:
