hello
I am running some CSV imports to load numerous issues
The import is failing for date formats on 2 fields: target start and actual start
I have tried all formats and change the format (eg dd/mm/yyyy) on the 2nd screen of the load but nothing is working
However, we also map a date to the "due date" field in Jira and this works perfectly
The only thing i can see on the field definitions is that target start/actual start are "date time pickers" whereas due date is just a date
Has anyone had this issue / found a resolution?
regards
Sarah
Maybe these topics will give you some idea
thank you
i have tried all of those options
my error is
Please enter the date in the format "d/MMM/yy".
but my dates are in dd/mm/yyyy format and i have added this as the format on CSV load
I have also tried yyyy/mm/dd yyyy-mm-dd
I wonder if its because these fields are on advanced roadmap
That seems to be it - in such a case you can only vote on the issue created in JIRA and hope they fix it soon.
