Calculate total story points in a given month
Matthew Ragone
September 8, 2020
I need a JQL that can do all the following:
1) Add all story points of stories, bugs, new features, and improvements in a given month.
2) Only count story points greater than 0 and anything larger than 20 is a waste.
3) I need the filter to be reusable so it can be applied month-to-month.
4) I need the total story points displayed in confluence.
Darrel Jackson
September 8, 2020
Can you provide a bit more context on why you're wanting this report? Is this because you're managing one or more Scrum teams and you're trying to measure various sprint-based metrics?
If so, there is a lot of out of the box functionality to report on Sprint metrics that are probably better suited than a JQL Filter.
Trudy Claspill
Hello @Matthew Ragone
Welcome to the community.
Jira will not calculate story point totals in that way, out of the box. You will have to look into an app that will give you that sort of additional reporting capabilities. Here are some of the challenges.
- JIRA doesn't track the month in which a story is completed. It tracks the full date a story was completed, and does not provide any filtering or aggregation based on the month of completion.
- You want a "reusable" query. If you want a query that you can use each month without modification each month, then you could use something in the filter like
resolutiondate > startofmonth() and resolutiondate<endofmonth()
but the filter would have to be run each month to collect the data. JIRA doesn't provide a method OTB to "prompt" for a user to supply a value to plug into a filter.
You might be able to find an app that would generate a bar chart for you, aggregating the data per month specified in the resolution date, and totaling the Story Points field. Then your query would just need to filter for the issues based on project, type, and story points being greater than 0 and less than 20.
Matthew Ragone
September 8, 2020
Thank you so much!
Do you have any suggestions of apps I could use for this? I am extremely new to this so any help would be greatly appreciated!
Ahmed Arslan
Can you try installing this one: https://eazybi.com/products/eazybi-reports-and-charts-for-jira
Learn more
