Can Feature file be uploaded in Jira to maintain test cases?
Veena Dubey June 2, 2017
We have Feature files for test cases which we want to upload in Jira with Zephyr to maintain the test executions and status, is it possible?
Arun Ravindran
Thanks Nic and Nick.Appreciate your inputs a lot
Hi Veena
If I understood your query correctly , you cannot bulk import files as such to Zephyr using our importer utility
As Nic and Nick mentioned you can import test cases, test steps,Label etc using our importer utility and then manually uplaod files to each test cases imported
Also please note that our importer utility is an open source.Theresore you can modify it as per your requirements
https://bitbucket.org/zfjdeveloper/zfj-importer/src
Zephyr Support
wadey
June 2, 2017
Zephyr has a JIRA import utility with a very comprehensive guide on how to transform and structure the content of your current written test feature files into a set of fields that can be imported - you can find it here: https://www.getzephyr.com/insights/getting-started-zephyr-jira-importer-utility
Hope this helps.
Veena Dubey June 4, 2017
Thanks Nick, but this doesn't solve my query if I can upload Feature Files as test cases in Jira.
Nic Brough -Adaptavist-
June 5, 2017
I think your "feature files" need some explanation.  The Zephyr importer does import test cases for use within Zephyr, but you need to explain why it's not working for your files.
wadey
June 5, 2017
Hi Veena, closest thing I could find with a little Googling is a Cucumber format known as a "Feature File". Like Nic mentions, at this point it's probably best if you describe those in more depth to Arun from Zephyr on the reply below.
Hope this helps, -nick
June 2, 2017
You can attach files to JIRA issues, but I'm not sure that covers all of your question.  Could you explain a little more about what you want from these files?
We have written test cases in Feature files but would like to run then using Zephyr along with test steps and data, is it possible to upload and convert in correct format?
June 2, 2017
Ah, I see, you have written test cases in one format, and want to convert them into Zephyr cases.
I think you should have a look at the Zephyr importer functions - they have ways of importing test steps, but you may need to convert your "feature files" into a standard format for them.
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
