Can I control the fields shown in the 'Issue Details View' on the right of the backlog
SallyD
We use the Scaled Agile Framework so I have added a couple of custom field for sizing and prioritization of stories.  Is it possible to include these custom fields in the issued detail view, preferably above the existing Estimate field?
SallyD
thanks.  Got it!
Wazza
December 20, 2015
Hi @SallyD,
Depending on which version/s you're running, you can configure your issue detail view by selecting Board > Configure, and then selecting Issue Detail View. This will allow you to add fields and select their order. You can't, however, add or remove the estimation field here, or order anything above it.
Hope this helps!
Warren
