Can I create a report with total story points per project stage?
Roberto T August 13, 2020
For example, I need to know the story points totals for the cards in the To DO, Doing, blocked and Done step.
Is this possible?
August 13, 2020
Hi @Roberto T  -- Welcome to the Atlassian Community!
There is no a built-in way to do this with out-of-the-box JIRA.  There are marketplace add-ons to do this with query scripting or charting gadgets.
For a free solution you could:
  • Create a JQL filter for your in-progress items, such as the following which would return the issues in progress or finished within the last 14 days.  Change myProject to your project name.
project = myProject
AND status != Backlog
AND (resolved IS EMPTY OR resolved >= -14d)
ORDER BY status
  • Add the story points field to the displayed columns
  • Export the results
  • Open them in a spreadsheet to sum the results by status
Best regards,
Roberto T August 14, 2020
Thanks Bill
I'll try that way.
Best regards
Like • Bill Sheboy likes this
August 14, 2020
If this works for you, please consider marking this question as answered.  That will help others in the community find solutions faster.  Thanks!
6 votes
Paige Kovar
February 1, 2021
Why has this not been added to the Filters feature as an option to appear at the bottom of the list?  Doesn't sound difficult at all - and making us go out to a 3rd party to have this ability, or exporting and using Excel, seems like a very immature-product solution.  This has been a frequent ask now for going on 5 years.
Jigesh Patel
October 23, 2022
Correct ! This is also has been a blocker for me to try more PMs and Business Analysts to use JIRA. Often many managers are interested in knowing how much work is left, when I answer them about "add ons" and export many of them are straight away disengaged.
October 24, 2022
Hi @Jigesh Patel -- Welcome to the Atlassian Community!
Are your teams using versions or epics to manage your work?  If so, you could try the relevant burn charts to help see the remaining work.  The use case noted for this thread was generic about summing the information, and so if you have other criteria (other than version and epic containers) you could also try the dashboard gadgets.
Read the story
