You can, but only in limited ways.
First, you say "Administrators and myself" - you can do that in permissions.
The second option is to use workflow properties - if you add jira permission properties to status, you can remove the right for some people to (re)assign the issue while it is in that status.
Hi Nic,
Do you mean settings for these permissions?
What is the difference between the 2 permissions in the attached photo?
Eitan
Yes.
These are not directly complementary permissions, but they do work on the same field. You can have people who can only assign issues, but not select themselves, and others who can be assigned issues, but not change who the assignee is.
Hi Anuja,
I can't use ScriptRunner becuase I use JIRA-CLOUD.
There is another soloution?
Eitan,
