×I have a custom radio button field with two options, but in a transition, None also appears. Am I stuck with this, or can I remove None or use a different field type?
Hi Phil,
Make the field mandatory and the None option will disappear.
Please see my reply to Coley's answer: Where is Required set, please?
It works, Thank you! :)
Hi @John Funk I followed your advice, but my problem is that my automations that are supposed to transition issues are failing now. So I had to make the field optional again.
Do you have any idea why the transitioning is failing due to the required field, even though I have set a default value? It seems like a bug to me.
"Transition issue
Error transitioning issues
KEY-1993 (FIELD is required. (customfield_10147))"
Hi @mb You can put in a log action prior to the transition to log the 10147 field to see what value is in it. You might have a default value for it, but existing issues probably have a null value in that field. Make sure you have a value in the field for all existing issues.
The clarity you are looking for is with understanding the "Field Configuration Scheme" and "Field Configuration"
This is associated to your project(s) and maps a 'Field Configuration' to an 'Issue Type' for your project(s)
This determines the settings applied to every custom field including:
You have to be careful about making this Field mandatory because you need to make sure that it is applied only to the Project(s) and Issue Type(s) you want applied.
Hopefully this helps.
Kris
It sounds logical, but I don't understand how to trace my field back to a Field Configuration Scheme and set it to Mandatory. The field is in fact only used in the two issue types I need it to be, and I think it won't appear anywhere else.
I created a new Field Configuration, and in it, set my field to Mandatory, and reloaded my issue page. However, in my transitions, the field still shows option None.
Did you associate the Field Configuration with the Field Configuration Scheme used by your project?
Share a few pictures:
I can't find the field configuration scheme. I only found 'Field Configuration' in the project summary.
Screen scheme
Field configuration (Note: the issue type symbols are the correct ones.)
Field context (Note: issue types are highlighted out of view)
Project summary field configuration (Note: There is no field configuration scheme entry.)
Request Dev Tasks screen with None displayed for Software Move Type field
I just now created a new field configuration scheme, and added to it a field configuration I had created before, that makes the Software Move Type field Required. There still is no Field configuration scheme appearing in project Summary, and the transition screen still shows None.
Field configuration
Hi Phil! This one goes over your question and the answers are great there, no use in recreating the wheel :)
But...Set it as Required ('Mandatory') where? I don't see that configuration in the Configuration dialog box.
Anyone knows a solution that would apply only to transition screen and not creation screen?
