I was curious if I am able to use the search bar to go through all of my issues and retrieve the issue based on the pid. I know that projects show the pid in the URL, and was curious if I can search based on that id.
I know I can search based on the JIRA Key (XXX-##), however I am mainly looking to see the the project level items only.
From my own basic testing, I couldn't do it, but I figured I would give it a shot here.
I think that JQL such as
project=1234
will work with the project id. It looks for the id first, then the project key, then the project name IIRC
Hello @Caroline Pastorelli
Welcome to the community.
Can you clarify what you mean by "project level items"?
Also can you clarify what you mean by "pid" and give an example?
Projects are containers for issues. There can be different types of issues (i.e. Epic, Story, Sub-task), but all of them will have a Jira Key that includes the Project key and a number.
You can search for all issues in the project using
project=<projectKey>
project="<project name>"
Projects do have a unique numeric number associated with them also, but the Project Key rather than that unique numeric id is what is typically displayed in the URL.
If by "project level items" you mean that you are looking for all issues that are of a particular issue type in a project, you can do that using variations on the following:
project=<projectKey> and issueType=<issueTypeName>
I know what you meant by "pid". That may not be the same thing @Caroline Pastorelli means by "pid". That is why I ask for them to clarify their terminology.
Hey, Thank you for the help on this!
To clarify by pid: when selecting a project, I select the Project Settings button on the bottom left of the page. Once the Project settings page loads, at the end of the URL: it says pid=#####. That is what I was referencing.
My apologies for the confusion!
Is there still an outstanding question? Let us know so we can provide additional advice if needed.
This is no longer an outstanding question, thank you for all of your help! I am able to search for the project based on the pid when using JQL with the query of project=pid#.
