Can I set permissions to certain users not to see the roadmap (including the the epics)?
Noa Buchman December 28, 2020
If this is not possible how do I set permissions for a board or a project?
Thanks a lot.
Walter Buggenhout
Hi @Noa Buchman,
Assuming you refer to the basic roadmap - not advanced roadmaps of the premium plan - they are a feature you toggle on or off for an entire project. So you can't target specific users to see it or not.
Regarding project permissions, check out Project permissions documentation. Mind the difference between classic and next-gen projects and make sure to check out the guidelines that apply to your project.
Noa Buchman December 29, 2020
Thank you @Walter Buggenhout for the answer.
Register now
