×I have a great JQL Extended Search format that I use all the time and wondering if I can possibly create a quick filter based off that Extended search? It looks like you can only put JQL in for Quick filters on a board, is there no way to have a named Filter that I can use for a Quick Filter?
Hello @Mark_Hortman
If you can save the filter you created with JQL Extended Search then you can use
filter = "<name of saved filter>"
...in a Quick Filter.
Hello @Mark_Hortman
Did you test this out? Did it work for you?
If it did, please consider marking the Answer as Accepted.
If it did not, please let us know what problem you encountered when you tried it.
It does actually work
