Can I use 'rename Group in jira' app in Data Center?
윤의연 February 27, 2023 edited
We are looking to rename group names in Jira and Confluence using Rename group in Jira add-on can we rename group names in confluence with the same add-on?
(We use Jira Data Center V8.22)
Trudy Claspill
Hello @윤의연
Welcome to the Atlassian community!
Take a look at this post to see if it addresses your question.
https://community.atlassian.com/t5/Jira-Software-questions/Rename-group-names-in-Jira-and-Confluence/qaq-p/2250619
If it does not please provide more information:
- Are you trying to use that Jira app specifically in Confluence?
- Or is Confluence using Jira as its source for users and groups and you are asking if the change in Jira will roll over to Confluence?
Thank you for the prompt response!!
We just want to rename our Jira Software's group name.
Can we use 'Rename Group in Jira' in jira Data Center?
Trudy Claspill
The information in the Marketplace does not indicate it is supported for Data Center.
I suggest that you contact the vendor of the app directly to ask that question. The contact information can be found on the Support tab of the Marketplace listing.
 https://marketplace.atlassian.com/apps/1222423/rename-group-in-jira?tab=support&hosting=server
Like 윤의연 likes this
Dang Thi Thuy Tien
February 3, 2025
Hi hi!
Changing group names in Jira/Confluence doesn't have to be a hassle. With Group Master for Jira/Confluence, it’s quick and easy! It just helps keep things organized with minimal effort.
If you need a hand, give it a try!
https://marketplace.atlassian.com/apps/1236395/group-master-for-jira?hosting=datacenter&tab=overview
And other advanced group management capabilities:
    View group usage across Jira
    Edit group names for clarity
    Move or copy group members easily
    Replicate or migrate group usage
    Delete groups and clean up associated data
